Ga door naar hoofdinhoud
Samsung Galaxy smartphone featuring a large display , and large font size.
44 Vragen Bekijk alle
Screen does not turn on
When pressing a home or power button, the phone illuminates the "menu" and "back" buttons, then after a few seconds the screen shows up for less than a second, then goes black again.
After 3-5 tries, I may get lucky and the screen finally turns on so I can unlock the phone and use it.
Are there any solutions before I try factory reset?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There are some step to reset your phone in safe mode
press the power key and hold for like 20 sec .
now tap the power off option .
just press the power key and hold if for more than 1 min
keep holding it . it may ask you to confirm the safe mode
please confirm it and wait for 1 min .
And second method is -
To Boot android phone in safe mode you can also try Volume Up + Volume Down + Power without doing reboot on your phone .
this may take you to recovery options also be care full here you don’t want to end up resetting your phone and losing you settings and data.
Note- But I think Your phone is just a hanging problem because of some virus so after reset update new antivirus.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you!!!
door
Voeg je antwoord toe
megajinn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 56
