Ga door naar hoofdinhoud
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
12 hour format instead of the 24 hour?
Does this model come with the 12 hour format instead of the 24 hour.
Is dit een goede vraag?
Score 3
3 opmerkingen
Tough one... The user's manual does state that the radio uses a 12 hour clock, but I read 3 reviews that both stated that the clock uses the 24 hour format.
door
I purchased ICF-C1 from Harvey Melbourne. It cannot change the time format to 24 hrs
door
any one can guide me to change the time format to 12 Hr
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
https://docs.sony.com/release/ICFC1.pdf
That might be of use.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you! Very helpful. I am from the UK and after a little research I found out that the 24 hour format is for UK clocks and the twelve hour ones are for America manufactured clocks. I prefer twelve hour, so I will just order it online from America instead
door
But isn't there an option for both of them for switching the time format from 12hour to 24 hour and back?
Thanks
door
I wouldn't. America uses 120v whereas the UK uses 230v.
Voeg je antwoord toe
Sam Melrose zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 71
Altijd: 11,415
