2013 V-Star 650 engine stall at engaging gears
With the side bar up and the clutch lever pulled the engine stalls when You engage the gears. It started after an oil change where I used Valvoline durablend 4T semi synthetic oil for motorcycle . I suspect a malfunctioning side bar security switch but not sure.
The motorcycle has only 48 miles run, almost new.
Could it be a clutch malfunction? I already adjust the clutch cable.
I brought the motorcycle from USA to Belgium.
Please, some idea will be very welcome.
Regards
Hector Alfonso
Is dit een goede vraag?
2 opmerkingen
@hmalfonso the model on the bike itself, is it a XVS650?
door oldturkey03
Is your problem solved?
door James Sanii
