Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
778 Vragen Bekijk alle
Unit shut down as if thermo overload
My unit shuts off as if it had a heat overload, but now it will not reset automatically. I have even let it set for a few days and was only able to get logged into a game before it shut down...and would not reset long enough to even get the game out....HELP!!!!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
I would start of by doing a hard reset.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
If that will not resolve your issue I would treat it like the YLOD Just do a search on google and you will literally find 100's of sites that deal with it. I also have a repair and upgrade guide for the PS3 that you can download if you like
http://www.keepandshare.com/doc/2510513/... and http://www.keepandshare.com/doc/2510514/... and http://www.keepandshare.com/doc/2510523/... and now the last http://www.keepandshare.com/doc/2510524/... it's a big file and very complete information. Good Luck to you
Was dit antwoord nuttig?
Voeg je antwoord toe
Richard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,130
