Ga door naar hoofdinhoud
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
262 Vragen Bekijk alle
Replace digitizer from another Note 4 (not replacement kit)?
Is it possible to swap out the digitizer from another Note 4 in to my own device, without doing damage to the S pen functionality?
When you pry open the screen you apparently damage the copper film -- what is the purpose of this film, and does it damage S pen functionality?
The replacement screen kit everywhere I look is the same price as a used Note 4, or Chinese phone, so the only cost effective option is to buy a broken (for parts) device on eBay that has a working screen.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
I've done it before without any problems. Also, I think you're talking about the contact point for the digitizer on the glass.
As long as you're careful you should be fine. I frequently swap parts of devices. The only times I've had problems were my fault i.e. rushing, being careless, ect.
Good luck.
Was dit antwoord nuttig?
Have same problem here. OLED is apparently fine but the digitizer is glitchy.
I did also find a crack in the top which *may* be why it had issues but can’t tell for sure until its completely removed.
I'm wondering the same. And John or Andre did you try this? And if so, can you share the outcome please. Thank you much.
Voeg je antwoord toe
John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 446
