Ga door naar hoofdinhoud
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
250 Vragen Bekijk alle
Why the Nintendo DSi powers up for a second then shuts off?
Battery is fully charged, but the device powers up for a second then shuts off.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
has the unit been droppedt? If it has the top screen is busted or the power fuse has been broken off the motherboard and requires it to be resoldered on. If neither of the these has happened then the top screen has went bad and needs replaced.
Was dit antwoord nuttig?
Score 1
You might find this article here on iFixit useful if you're going to replace the top LCD screen. Hope you can resolve your problem.
Score 1
Check the power fuse. If broken it prevents the DSi from coming on. http://m3wiki.com/index.php/Nintendo_DS_... shows you what to look for and how to do it....Good luck
Voeg je antwoord toe
Charles Browning zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,115
