Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
1360 Vragen Bekijk alle
6 Plus LCD screen & Digitizer Full Assembly
I purchased and just installed this on my phone. My understanding is that it came with a camera and earpiece, but neither components are working. My understanding also was that it would also fix the screen, but 1/2 of my screen is still black. The only thing so far that it's fixed is my screen is no longer cracked. Please tell me what's going on with this. Thank you
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
What did you purchase? Cracks in cell phone screens don't go away. they have to be changed, so if your screen was really cracked and you didn't have it changed then it's still broken.
door
I just purchased this and received it today. I purchased the iphone6 Plus LCD screen and Digitizer Full Assembly. This should've been a easy fix. But, Thank you for answer.
door
What I purchased was basically a brand new screen (Fixed the Broken Screen Issue) However, Thispart didn't fix the 1/2 black screen issue and I'm a little confused because I purchased this particular product to fix the broken screen and 1/2 black screen and not have to move the earpiece or camera to new product
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
3 Antwoorden
Gekozen oplossing
Digitizor needs changed,
Was dit antwoord nuttig?
Score -3
Commentaar:
This is not a good answer.
door
How in the **** can you say my answer was a bad answer? The person never said what they bought and what they installed, Dahhhhh, then they never said they changed the SCREENNNNNN. They just said after they installed what they bought was suppose to fix two problems that wasn't even related, If they'd have said what they had installed and then only half the screen worked then dah retard it would be the digitizor. So keep your mouth off my comments and get back to class.
door
The digitized is not responsible for displaying anything. There was no mention of a lack of touch response. To leave such a vague answer isnt helping anyone. To respond so aggressively is also not a great show of character
door
Right on Eric.
door
Het nuttigste antwoord
@logansangel4evr you are probably trying to fix what seems to be a board problem by replacing the screen. At least for the half-dark screen.
Other possibilities: you are not seating the connector in place properly, or the back-light pins on the replacement screens are uncovered and touching the frame.
As for the camera, I would think either the replacement camera cable is bad, or you damaged it during replacement, or the issue is also on the board like for the half-dark screen.
To help you determine the causes and possible solution, you need to share some history about your iPhone: liquid damaged? Previous repair attempt? Chronologically please.
Score 3
The screens that get shipped out generally dont have speakers/sensors/home buttons. You will need to transfer these from the damaged screen.
The issue with the black portion of your screen may be due to the connecter on the board.
Inspect where you disconnect the flex cables and be sure they are fully pushed in.
The 6s has a long connector on the top portion and can often take a couple tries to get on correctly
Be sure to disconnect and drain the board by pressing/holding the on/off button with the battery disconnected
best of luck,
Eric
Score 2
Commentaar:
I purchased this one because it read it has Front Camera Assembly & Earpiece Speaker. I knew the home button would have to come off my broken screen. So, I'm a little confused why I would have to replace the camera and earpiece (Especially for the price). I also checked all the cables and connectors. My phone was like this before I replaced this part. Maybe, I'm confused, lol. But, I will definitely try that agin. Didn't try the button with battery disconnected though. Thank you for your help and answers.
door
And the speakerphone works, it's when I take the phone off speaker, nothing can be heard
door
Ear speaker problem is most likely a connection issue. It's either the connection to the logic board, or how it's mounted to the display assembly.
door
Voeg je antwoord toe
Rhonda Logan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 114
