Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4564 Vragen Bekijk alle
Deleted message by mistake, can I recover it?
How can I recover a deleted message that was deleted today, 4/12/17 by mistake
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Commentaar:
Try iRefone which supports recover any data including deleted messages from iPhone.
door
You can depend on efficient recover tol.Mobikin Doctor for iOS.If your data has not been overwritten,the program will sacn the deleted messages automatically.
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
3 Antwoorden
Gekozen oplossing
Not totally possible if you didn't happen to have a backup performed after the message came through, but before you deleted the message. If you did have that backup you can restore from iCloud or iTunes.
Was dit antwoord nuttig?
Score 4
Commentaar:
This is totally right. I didn't even think about it. So most people have their phones backup daily. It usually happens at night, while plugged in, and connected to wifi. So you could backup the phone, to that backup, before you deleted the message. Yeah, you could lose some stuff. But it would be very minimal. Wow. Good answer @cvneutron
door
As Matt Zieminski says, if you have backed up your iPhone before, you can try restore. But this might replace all existing data and the process is to some extent complicated for new users and time-consuming. If there is no backup, the only way to retrieve deleted messages is using an iPhone message recovery tools, and you should avoid using your iPhone to prevent the deleted data been overwritten so no tools can recover them. Try PhoneResuce, Dr.fone, Primo iPhone Data Recovery, great tools to retrieve iPhone messages. Here is a guide: https://www.primosync.com/support/how-to...
It's very likely to delete some important old messages by accident, regretfully. Actually, after you remove a message from iPhone, the message doesn't actually get deleted. You are most likely to recover deleted text messages if you act quickly right after accidentally deleted them. That's because those texts won't actually lost until they are overwritten by new files.
Voeg je antwoord toe
Jordan Vaughan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 313
