Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Deze instantcamera van Fujifilm heeft nu een dunnere en lichtere behuizing dan eerdere revisies. De Mini 8 helpt de fotograaf door de aanbevolen diafragma-instelling aan te geven. Hij beschikt ook over een High-Key-flitsmodus waarmee de fotograaf zachte portretfoto's kan maken voor een verbluffend resultaat.
Why are my pictures coming out distorted in color and leaking ink?
So i have had this forever and today i put in a new film, and for some reason, it's not working. My pictures are coming out of the top, however, they come out with ink on them and with color all over the picture. The picture that i take is not visible and the only thing that is, is the ink and the discoloration of the pictures. Please help me!
Update (04/10/2017)
here are some pictures
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Is dit een goede vraag?
Score 5
2 opmerkingen
How long have you had this for?
door Deel
1 day !,!!!!!
door Deel
Voeg een opmerking toe
10 Antwoorden
Filteren op:
Het nuttigste antwoord
Hey, I had the same problem and I used a different type of film.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I had this problem and this worked thank you so much
door Deel
Can you please recommend what films do you use?
door Deel
Hey Maya, I've had the same exact problem except mine turns blue and my mum bought it for me not quite long ago and after I've taken the photo it just turns blue idk what to do please help me.
Score 2
2 opmerkingen:
My camera does the same thing. I don't know what to do.
door Deel
I recently bought my camera and it does this too and it keeps on auto turning off
door Deel
I think it has to do with the rollers. I’ve taken a film from the film cartridge and the ink comes from the bottom. When it rolls through the rollers I believe they are supposed to push the ink out. I could be wrong though but I think it has to do with the rollers.
Score 1
Without knowing much about this camera at all, that sounds to me like maybe a bad roll of film? Do you have any others you could try?
Could you upload a picture of one of the pictures that isn't printing correctly?
4 opmerkingen:
i have one other one i can try. I'll try that and see how that works. What would you suggest if the problem is still there? and sure, ill post some pictures right now
door Deel
hey tried what you said and the same thing happened
door Deel
Maybe something inside is pinching or poking the film? I really don't know much about this camera, so I can't offer a great answer, unfortunately :/
door Deel
i have just got it today !!
OMG!!!!
door Deel
Hello Maya!
I have exactly the same problem, do you know from where does it come from?
Could you fixed it? The film? The camera?
Thank you.
Emeline
7 opmerkingen:
hey! i haven't been able to get anyone to diagnose the problem. i don't know what the problem is and idk where to take it to get the answer. i really don't want to buy another one so if you figure something out, please lmk, as i will do for you as well
door Deel
:( I don't know neither for the moment, I'll send the information where I bought my camera. I think the problem comes from it. Not from the films.... I'll tell you if there is an answer. Thanks to you!
door Deel
awww poo!!! Alright, thank you!!! Please, whatever information you can provide me would be helpful. The information where you brought it and anything else! I'll keep you updated
door Deel
A question : Did you travel by plane with these films? (Maybe They've been damaged by the X-ray scan....)
Did you try with new one just bought?
I still don't know what happened./..
door Deel
Hello Maya!
For me, problem solved !
I've been to a camera shop to fix it, but at the same time I change by a new film just bought. And it's work.
The guy from the shop just cleaned inside but didn't see anything wrong. For him it was the films.
In fact, those films travelled with a friend by plane, and was not in the cabin. I think the problem is made by the X-ray for control in the airport.
What about you?
door Deel
2 commentaren meer tonen
i think that the film was over exposed and not fully developed. maybe if you try a new film or check the inside of your camera you will find the problem. Maybe the infrared blaster?
i’ve used two packs already and they all come out the same. ink all over them, and some don’t even develop. i’m scared because i’ve only had this polaroid for two months and i have a trip in a week that i want to take polaroids at.
Afbeelding
Here is what happens to me. I really don’t know what to do. D:
2 opmerkingen:
Your film has probably been exposed.
Did you try with another new film, not bought at the same time?
( because if it travel together, it could be exposed to X-ray for example, like for me when my friend traveled with it, but not carrying it in the cabin)
door Deel
What do you mean by exposed? And also I just bought it the day before yesterday. So it wasn't the x-ray.
door Deel
Hi, Try charging your polaroid overnight / for several hours. Mine was doing the same thing for a while until I cleaned the rollers (located were the film is placed and on the outside where the film comes out) and charged it overnight.
You need to clean the ink that leaked out on to the roller but yeah i fixed it on my camera.... something
Voeg je antwoord toe
Maya Santiago zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 78
Altijd: 36,479
