Ga door naar hoofdinhoud
iPhone 7 home button not working after screen replacement?
So I currently work at a repair shop, and so far 1/3 customer iPhone 7/7 plus has been a success. Everything seems to be working fine except for the home button. I know for a fact that there can't be any damage to the home button flex since I've removed it very carefully and installed it carefully as well. Same 4 screw and everything but no luck. I even used the customer old screen and marked it as a no fix but sadly it stopped working with the original screen as well. It bothers me so much not knowing what I did wrong??? As I've done over hundreds of iPhones and never broken a Touch ID Flex before. Is there a technique to removing one cause I mean from my experience a iPhone 6 Touch ID with the heat plate is harder to remove than the iPhone 7's.
Is dit een goede vraag?
Score 15
24 opmerkingen
Where are you getting your screens from?
door
Hey Gigabit878, I wish I tell you but corporate orders the parts and we just do the repairs. I don't think its a screen issue since I've connected the home button to the original apple screen as well and theres no function.
door
I own a repair shop and have been working on iphone's since the iphone 3.
The bottom line is this: The iphone 7 is the Apple Cooperation's 1st real attempt to prevent after market repair shops like us from repairing their phones. See Repair.org's website as they are lobbying in several states to stop this as it is unconstitutional. The Home buttons are electronically linked to the LCD's and will almost 100% of the time detect a screen replacement, even a premium original refurbished apple one. Motherboard.com published a picture of a device that the Apple stores use to change out LCD's and re sink them the the motherboard. The only way we have found to repair the 7's is to remove the frame and gorilla glass (working LCD and digi only) and replace it using loca or oca glue. This way your are keeping the original LCD and home button intact and together. If you want to stay in this business, you will need to learn how to preform this repair and acquire the proper equipment.
-Joe
iPhone Repair Hospital
door
Sorry Joe, but I disagree, I've been using original refurbished screens for a long time on the iPhone 7, not the original one that came with the phone either, and it's been completely fine every time.
I think most techs are either making mistakes, or they are using low quality garbage which is causing them issues.
They aren't even linked to the LCD, if that was the case, we wouldn't be able to change LCDs at all.
It is hooked through an extension flex that routes under the 3D Touch panel, I refurbish screens myself so I know this.
Also, why did you even mention LOCA? LOCA has absolutely no place in iPhone screen refurbishment, especially on the 6S and above, as it messes with the 3D Touch.
Yes, a lot of people have seen the 'horizon' machine that Apple use to pair a new home button to the phone.
Please don't spread false information, you can absolutely replace the iPhone 7 LCD and still have a working home button, people need to stop using low quality garbage, and be careful during the repair.
door
Has this problem been resolved or is the home button still an issue?
door
19 commentaren meer tonen
Voeg een opmerking toe
20 Antwoorden
Gekozen oplossing
I've seen this question crop up a lot when it comes to the iPhone 7 and 7 plus, and I'm going to throw in a few ideas.
One of the biggest reasons it doesn't work, is down to screen quality, copy screens just don't tend to work with the home buttons, this could be due to missing traces in the cable that don't support it, or could be something else.
I've used original refurbished with every repair and never had one issue so far.
When removing the button from the original, I know people say they remove it carefully, but the home button removal procedure is a little more difficult compared to previous iPhones, especially since the extension cable isn't stuck down, this requires you to get a spudger and hold the extension down whilst unplugging the button.
You also mentioned that the home button also didn't work on the original screen either, this may be because you damaged the home button flex, or you have damaged the extension cable on the original screen, I see a lot of people lay the screen flat after they have opened the iPhone, this causes stresss on the flex and may break traces inside that cable, or again, may have been broke during removal of the home button.
Always try to use original or original refurbish, if this doesn't work, it may be the extension cable that's faulty, if it doesn't work with another replacement, you may have damaged the home button itself.
Also check that you haven't placed the bracket under the shield, it needs to be on top of the shield.
A tougher take on a favorite multitool. Safely poke and pry with this tough, firm, and antistatic tool for electronic repair. 5” carbon fiber tool essential for smartphone or tablet disassembly. Afbeelding
Product
Spudger
$3.99
Was dit antwoord nuttig?
Score 10
12 opmerkingen:
what bracket/shield are you referring to in your last tip?
door
The home button bracket :-)
door
Does having the bracket above/below affect touch ID and home button functionality?
door
I believe it can if it's not put on correctly as it apparently causes a short.
If that's not your issue, you need to look elsewhere, such as possibly your screen (the extension flex that connects the home button)
Or possible tear in the home button flex.
door
Hey,my iPhone 7 got water damaged and the screen went blank but the home button was working than after it came back from repairs the home button is not working but it should work because it's connected to the LCD and the LCD is working
door
7 commentaren meer tonen
Het nuttigste antwoord
Yes, rule out bad screen, and it sounds like you did that by putting it back on original screen.
iPhone 7 home buttons are finicky, the screws on bracket don't like to be overtightened. What we are seeing now is that the turtle ic (also called U10 in China) on the home button flex itself is easy to damage. This ic controls the transfer of capacitive home button pressure input into ones and zeros that the logic board can understand. If you have an iPhone 7 that has home button not working after screen swap, but touch ID DOES work, then that really points to turtle ic which can be changed by microsolderers.
Torn flex is also a possibility but it sounds like you are being super careful not to do this--especially after you had a failure with the first one! I've seen one with a tiny pin !$$&* of flex damage from tweezers. You can look at the flex under a microscope to see if you are damaging the flex.
Lastly software--in a scenario where you put a home button on a bad screen and then swap it back to the original for troubleshooting you may need to reboot the phone once to rule out the board just ignoring the home button sensor.
good luck!
Jessa of iPad Rehab
Score 14
3 opmerkingen:
I think I have this problem you mentioned about the overtightening. My home button works but touch ID doesn't. Is the turtle IC located on the home button itself?
door
I had this issue on a 7+ screen replacement, every iphone 7 ive repaired works fine but this once, on a 7+ (first one) gave me so many issues, at first the earpice gave me issues and short circuted with the camera, and that pice wouldnt work which caused the speakers not to work. Now i ficed that and the homebutton still has the same issue, of working with touch id but failing to register a down press and activate the homebutton
How do i fix that? Or where exactly is it located
door
what I think a couple of people misread what Jessa said. She said if the Touch ID IS working but the home button's pressure input was NOT working then the issue most likely has to do with the Turtle IC. Just wanted to clear that up in case some were still having issues after addressing the IC and not having any luck.
door
It honestly has to do with screen quality a cheaper screen has a $@$* cable on it these do not have the sufficent traces to allow touch id and home button functionality.
The only screens I use are Mobiledefenders.com Premium i have never had a issue with the home button and touch ID also make sure you disconnect the battery first and always put it on last power to the board without the screen attached messes with the BioMetric Sensor on the Board.
Hope this Helps
Stephen T
CPR Cellphone Repair
Mobile Device Specialist.
Score 3
10 opmerkingen:
Honestly I don't think its the screen cable... I know exactly what you're talking about, with the 6s repairs theres always a few where it will always never work with the Touch ID. Reason why is because i connected their home button back to the original broken screen and it did not work as well... my co-workers have be discussing about this and seeing if there is a torque level in the center piece where the home button is.
door
Dude, it's your displays. 1 out of 3 successful? You've got to me kidding me? There's no way I would accept that at my shop
door
Agreed IMedic ive never run into issues except with cheap $@$* screens
door
Thanks for replying guys, and i understand your guy's answers. but it still doesn't solve the reason why the home button will not work with the OEM original screen from apple that the phone came with?
door
I wonder if the cheap screens are causing the home buttons to get damaged and stop working. But I've never had a case of that on iPhone 6s screens coming from my supplier.
door
5 commentaren meer tonen
I had the same problem - the problem was in the new display itself. (Reliable source, can happen) Ordered another screen, problem was solved. Guess the cable underneath the backlight/LCD that connects to your homebutton can be defective in some displays.
Score 3
4 opmerkingen:
This was my first-encounter with a home button issue IPhone 7....thanks to these answer it solved the issue. I know now how import is the quality of the lcd is .... Will be looking a better source to buy from...
door
This is a very common failure since the 6S.
door
i had the same exact problem and replace the home button but still not working any suggestions>?
door
The bracket on the back of the lcd is pinching the cable...
Solution...
bottom left screw ( only non y screw) screw it in without the bracket and let the bracket lay on top of the screw
door
My repair shop works on iPhone 7 and 7 plus' all the time, and out of the many hundreds that we've repaired, have had maybe 2 or 3 with bad home buttons or home buttons that stopped functioning. There is a very careful method to going about replacing the screens on these phones, whether with OEM/refurbished displays or aftermarket screens. As long as the H/B connector on the new LCD is good, than you should have no problems.
First of all, before doing anything, turn the iPhone 7/Plus off. Then, when removing the home button from the original broken screen, be careful in removing the screws, try not to put too much pressure on the plate covering the button, and avoid the screwdriver and the plate touching or puncturing the button during removal.
At this point, you want to disconnect the button from the original screens connector using thin tweezers and when doing so, make sure the tweezers don't make too much contact with the connector, and carefully disconnect it without too much pressure or force.
Now the most important part, removing the home button from the broken screen. There is an adhesive on the back of the button that sits on the frame of the screen. Don't put anything underneath the button and between the frame like a thin metal pick. Also do not try to remove it until you have applied heat...now how would you go about applying heat without damaging the button? Utilize a heat gun, like an 862D+, if you don't already have one, at about 100 degrees (the minimum for this heat gun). Point the gun directly at the circular area where the home button sits on the side of the screen behind the button. Wait about 15-20 seconds, and slowly and carefully peel the button off the screens frame with your finger from the connector, but if you notice that you have to be forceful or apply pressure, stop and keep applying more heat (as it's easy to tear the flex cable on the button). If you're worried about burning the broken screen (in case you want to refurbish or sell it to a refurbisher) than don't apply too much heat. If the LCD is already damaged, don't worry about this, it makes it much less stressful.
Once you've done this, carefully slide the home button through the circular hole and remove it from the front of the broken screen. Make sure you don't slide it across any broken glass in the process. Now take the button and slide it back into the new screen, and carefully connect it to the new screen. First thing you want to do is test the screen with the home button. I strongly advise against testing a screen without the home button connected as it could descramble the code and cause the button not to work no matter what screen you test it with.
Once you've done this, and you've confirmed that it's fully functional, turn the phone off, remove the screen, leave the button installed on the new screen, remove the mid frame/front facing camera from the broken screen, and carefully install it on the new screen. Make sure not to pull on the screens flex cables too much as that could cause the screen to stop functioning as well as damage the home button connector. Once you've done this enough, you will rarely if ever come across any issues with iPhone 7 and 7 plus replacements, OEM or aftermarket.
Hope this helps, thanks!
Score 3
I've never had an issue with the quality of the screen being the issue of a home button not working. I have however seen the issue to be a ripped or damaged home button flex or the back plate not being the original which has caused the home button not to work properly.
I've also read that any damage done to the home button will cause the button to never work again as well as even a replacement because it's not the original. You probably would need a new backplate and a new button for the button to be recognizable.
Hope this helps :)
Score 1
I also have the dreaded dead home button but touch id works fine, it's original button of course or ID wouldn't work but can't get the darn home button to work to save my life :( any suggestions? Phone was brand-new 3rd day was dropped lcd cracked not glass.
Score 1
2 opmerkingen:
It’s possible that the U10 chip on the home button has been damaged, which would need replacing.
door
I found the solution was no doubt the quality of replacement screen I found a really quality one on Amazon that fixed all my issues I tried replacing cables etc between software update and a good quality screen my iphone works perfectly as it should. This issue drove me insane when it first happened this world really well for me I am no way shape or form affiliated with the seller just my experience
Screen Replacement for iPhone... https://www.amazon.com/dp/B077S9KB3Y?ref...
door
I have a theory.
If there's no damage present and it doesn't work after powering up... Give it 15 minutes.
I'm finding recently that after a battery disconnect it is taking the home button a while to initialise.
This could be misinterpreted as a damaged button.
After a while it'll work.
Score 1
Hello Folks,
Recently I got my iPhone 7 plus screen replaced and got in an exact same situation where my touch id was not working though the return to home was working fine.
After doing a little research I finally gave a try to complete software restore.
Went to www.IPSW.me and downloaded the latest IOS 11.2.5 ipsw file and did a complete restore using iTunes
And voila the touch id started working fine again!!!
Please try it and see if it works for you.
Thanks
Score 1
Solution...
Score 1
I read this full article, so disappointed with people comments as they are talking same thing over and over, any I have also something similar to this brother like i change the LCD and home button didn’t work, I tried whatever people told above but nothing, what I did, I get another iphone 7 and take its complete front panel i mean lcd with home button from a nother working iphone 7 and attached to my iphone and home button still doesnt work, i forget to mention the phone I was working on had broken home button as well. Any body can help me to sort it. I changed several LCD and Home button replacements, generic and originals from the phone.
Thanks and your help will be highly appreciated
3 opmerkingen:
Only the original home button will work, no other button will work, OEM or not.
door
Just like Ged said before, only the original homebutton (the one that sits in your iPhone) will work.
door
I've done a ton of 7 and 7 plus, about half of the buttons work after and the other half didn't, the only solution I found was not taking the screw out that is in the home button but instead bending the bracket to get the home button out and to put it back in the new screen, that's worked perfectly for me 100% of the time on about 30 screens now
door
i'm going to have to agree with the quality of screen as the culprit in this situation. after the second instance in our shop with an iPhone 7 screen replacement causing, what seemed to be, a shorted circuit between the home button flex and the new assembly, we bit the bullet and began using original refurbished replacement screens.
2 opmerkingen:
Nope just unplugged the home button connector realised I hadn't the right pentelope driver and Plugged home button back in and booted phone up and home button hasn't worked since didn't even change the screen ? No damage to nothing ?
It's Apple up to something
door
Where do you get refurbished original replacement screens?
door
Try software...
I had iphone this week and I replaced the screen, before I replace I connected the lcd with out home button, and then put together everything and replaced the screen... after replacing I was testing the phone, and realize touch id is not working, after this I did again and starts working...
There is also this to consider:
Posted about the same time as the original poster...
Sorry Folks, iPhone 7 Home Buttons Aren’t User Replaceable
WRITTEN BY JULIA BLUFF
Bad news for the DIY-inclined: looks like the home button in an iPhone 7 or 7 Plus can’t be replaced with a different one. If you break the button or rip the cable, you’ll have to go to the folks at the Genius Bar for a repair—or be stuck with a completely non-functioning home button.
The iPhone 7 and 7 Plus appears to take this feature a step further. Home button replacement—or damage to the original home button cable—renders the button completely non-functional: no Touch ID and (here’s the new part) no return-to-menu ability. You can still navigate your phone by turning on Assistive Touch. But for all practical purposes, you’ve got a dead home button. One that you can’t fix on your own or at an independent repair shop.
Read the rest here:
https://ifixit.org/blog/9020/no-fix-ipho...
You removed battery cable ? First remove the cable from battery cannotar then whatever you will do any phone not only iphone 7 !
Dear all,
Problem with the home button for me too.
I bought a screen on ifixit for replacement on my iPhone 7.
No problem during the swap, but when I switch on the phone, it takes a long time and restarts two or times (apple logo then black screen then apple logo again).
Once it started, touche ID and home button don't work.
If I swap to the original broken screen, everything is fine, quick start, touch ID and HB work fin.
Do you have an idea ?
3 opmerkingen:
I had the same issue with iphone 7 plus... my solution? Put the iphone into dfu mode ...after...touch returned ....also at first i put the bracket on incorrectly...put it on top instead of underneath... have not had issues after learning on the fly lol
door
Hey Paul, which Bracket do you mean, I'm running into the same issue.
door
He more than likely was talking about the bracket to the h.b.
door
does home button heat up?
1 Opmerking:
hello yes i got one and is not a good news ! touch id sensor still work and stop when is too hot gonna try to found a fix if is possible ( this is not the screen and i will try to software dfu flash )
door
Hi all as of my experience I just want to test this issue cause because of replacement or apple software . want I did is I have my well working iPhone 7 I just open it and never replace any thing I just on the i phone in open condition suddenly the home button is not working even I close and fix the screws back. the touch id is disable totally not working. Personally my thought is because of software the lock it once you open the phone.
If you don't believe it plz try the same as what I did.
I am not posting an answer. I have researched this problem until I 'm almost tired of life. Firstly, why are there so many people who just do not seem to read and understand what others are writing , or trying to write about regarding this problem, then keep going on possibly this action will work or that item will solve it, the thread just goes on and on. For f***s sake.
YES the i phone 7 home button is digitally linked to the motherboard. You won't find how even if you have access to the many pay to use or download diagnostic and repair schematics. and softwares that are out there.
To all those that have successfully transferred an original i phone 7 into another replacement digitiser screen assembly, whether from Apple or a quality aftermarket supplier, you got lucky dude. 99% of the time the home button link to the system is disabled if it is ever disturbed.
A low current supply is permanently supplied to the circuit in the home button chip even when the phone is switched off. You will not ever find out how this supply works where it originates in the motherboard and where it routes through the rest of the system. You need Apples kit to reset everything at a cost that only you the customer can determine whether it is cost effective or not.
YES, it is a pain in the orifice. Its kick in the teeth as far as generating any continuing customer loyalty to Apple goes on the grounds of allowing cheaper repairs and replacements, especially as now the latast i phones X are costing as much as a second hand car. Its time to think about changing repair services to everything but Apple. After the last i phone 6 passes through my hands I'm done with them.
1 Opmerking:
Not how it works. You can disconnect the home button, leave it off for a week while you use the iPhone, put it back after a week and it will work perfectly - provided the home but has not been damaged in the process. Which occurs when the cable is torn or Turtle IC looses connection. Or components become shorted.
door
Im experiencing many of the issues on all the iPhone 7 and 7 plus, just today i had to replace the camera for a customer, and after installing the new one, the home button stop working. I called apple, them could not troubleshoot the problem, unfortunately and sadly all iPhone made after iPhone 6S are problematic, and yes i do agree with some one on this conversation, apple is preventing repair places to take the task on repair their products.
I have over 10 iPhone 7 with code (4013) send couple at apple for repair, there send it back, saying the items are beyond repair.
Apple is going to disappoint a lot of customers and especially hurting a lot of small business for doing the repair less than what apple offer.
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 143,192
