Ga door naar hoofdinhoud
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Vragen Bekijk alle
I only get a white screen with a crossed circle at startup
When I power on my iMac, it shows me the Apple logo for a minute and then a white screen with a circle with a line through it. I read on this site that this is due to a bad hard drive, so I replaced my hard drive with the recommended 2T Seagate (I am pretty handy). After hard drive replacement, I still have the same issue. I have tried holding down COMMAND R, and OPTION during power-up, but it doesn't change anything. That is supposed to take me to the disk utility menu so I can restore from my Time Machine drive, but it doesn't happen. Only the white circle with a line through it. What else could be wrong?
Is dit een goede vraag?
Score 2
7 opmerkingen
Please tell us your exact machine. If you don't know get the serial number from the bottom of the machine and we can look it up.
door
Are you SURE it's a Late 2009?
door
I have the same issue, replaced the hard drive, get the same symptoms. I am trying to boot from Snow leopard disk. But it just hangs at the progress bard being @ 1/3 complete.
door
i have the same problem on a macbook air running high siera and theres nothing that works
door
Problem solved.
Solution; turn your troubled device into an external drive by pressing the “T” key while startup. Connect your troubled device to another Mac with the same OS or higher. Open Dick Utility on the other Mac, select the troubled hard drive and click repair. It’ll probably take about 5 minutes depending on your hard drive size and how it is.
DONE! No need to reinstall any OS.
BTW once repaired, do yourself a favor and backup or clone your now repaired disk. I prefer cloning.
I hope this help you, peace!
door
2 commentaren meer tonen
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
If you can't start up from macOS Recovery
Newer Mac computers and some older Mac computers automatically try to start up from macOS Recovery over the Internet when unable to start up from the built-in recovery system. When that happens, you see a spinning globe instead of an Apple logo during startup. To manually start up from macOS Recovery over the Internet, hold down Option-Command-R at startup.
If you still can't start up from macOS Recovery, and you have a Mac that is able to start up completely, you might be able to create an external Mac startup disk to start up from instead.
https://support.apple.com/en-us/HT202796
Was dit antwoord nuttig?
Score 5
5 opmerkingen:
So I was able to get it started up with my Mac OS-X installation disk. I got it restarted and then did a Restore from my Time Machine back up. Bad news though, after the Time Machine restore my computer won't accept my startup password, so I can't start it up! I guess that may be due to a mismatch between the OS-X version on my Installation disk (from 2009), and the version which I was using when the Time Machine backups were made. I am guessing I will have to start over, reinstall from my Installation disk, but not restore from Time Machine. This will enable me to create a new user and password as if it were a new computer. Then I should be able to update OS-X from the internet, and essentially start over. Maybe I'll be able to selectively restore some files from Time Machine, but if I try to do a full restore I won't be able to sign on or use my computer at all. Any thoughts on why this password issue happened? Any way to do a Time Restore without that happening?
door
If you are using an original Apple installation disk, go to utilities > Change Password.
door
Yes! I've got it working , now with 2T HDD and 16GB of RAM, and restored from my last Time Machine backup. Thanks for all your help, I wouldn't have gotten it done without it.
door
Victory! Just like napalm in the morning ;-)
door
So I decided to reset my whole Macbook Pro because its my uncles. He let me borrow it for school. So I decided to do my classes on the laptop. But I couldnt because I needed the Administrator password. But here's the thing, my uncle didnt write the user or password. So I looked up on a website how to reset the whole thing so it told me to erase the Magitosh Disk and I did it but then when I went to reinstall the MacOS, it said it couldnt be contacted to the AFPS installation. I just powered down the mac and left it like that. The next day, I powered it on and I was waiting and when the apple screen finshed loading, a circle with a slash. I panicked. I looked on websites and found this one. I tried even the apple support website and wont work. PLEASE HELP ME!!!!! If you cant help then I'm doomed.
door
Try creating a bootable USB and use that to get into the install, then you can get into disk utility and restore it.
Score 2
4 opmerkingen:
I was sort of wondering how it was supposed to boot at all with a blank new hard drive installed. Without a bootable USB, what would it normally boot from with a new hard drive installed? Thanks!
door
Nothing as there is nothing for it to boot from
door
Depending on the age of your system you might have internet recovery is an option but you do need a good internet connection otherwise it can literally take days! We did an experiment and it took over 20 hrs to do the recovery using a cellphone's data service.
So lets start off getting the details of the system. What is your exact model as there are some other things that also play into this.
door
It is a late 2009 21.5" iMac. I have been traveling so I haven't had a chance to try it yet, but I did locate the Mac OSx installation disc that came with it when I bought it, I believe that is probably the missing piece and I will be able to get it going with that disc. Sort of a stupid oversight on my part I guess... I thought maybe the disc utility was firmware but I obviously need a working disc of some sort to boot from. I'll get back if I still have issues, thank you all for your very helpful input.
door
Hi Curt, just to clarify since it is possibly a 2009 make it will not have internet recovery, so performing an time machine would be ideal if you have it.
You can try all processes below, except it may be wise to reopen device and check all connections as if you were prompted with same error message could be the cable it self and not the drive as i replace many Mac and high possibility it is the hard drive or reseating the cable.
Performing the cmd+r - will boot you into the utility menu and select time machine when it appears
Though you can also press and hold the option key when your external drive is connected and be patient as it takes a bit longer than newer units. while holding the Option key only you will see three drives if any appear New hard drive, recovery drive (if any) and your external boot drive.
I have a few 2009 iMacs here and works but takes a good 30-50 seconds sometimes longer depending how much ram you may have for performance.
Finally if you have another mac or a friend with a mac you can download El Capitan 10.11.x OS X and create a bootable usb drive to boot from, but to be safe see if you have in purchases of the Mac App store or your friend to download the Mavericks version as some of the OS X's require certain ram prior to installing on the Mac.
Now this all depends on which model / year Mac that you have but a bootable Mavericks would do the trick going back to 2008 early iMac.
Thanks
www.MacOSGenius.com
Score 1
2 opmerkingen:
Should he hook up to an ethernet cable to improve this internet install? Will this model do an internet install? Does it need an EFI firmware update to do an internet install? Once Disk Utilities comes up, should the drive be formatted? Anyone that puts Genius in their name just scares the pee-pee out of me.
https://support.apple.com/en-us/HT202313
door
I have a 2013 MacBook Pro and I have the same problem. Can you please guide me t fix this problem please
door
Hi, I need help.
I have Asus computer windows and out of a I get this white pop-up screen with the message jqrszs and there's a code 0.0080 990791320801 please help to identify the problem with help this issue to get rid of the screens that popping up left and right just a white plain screen
Problem Solved.
First, turned your troubled Mac into an external hard drive by pressing the “T” key while starting up. Connect your troubled Mac to a good working Mac with the same OS or higher (connecting cables will vary depending on the year and model of your troubled Mac). Open Disk Utility on your good working Mac then select the troubled hard drive.
Click the repair button; DONE! That will solve your problem. No reinstalling no OS or reformatting anything nor using TimeMachine…
BTW, once your problem is solved backup or clone your now working Mac. I prefer cloning.
I hope this helps you, peace!
1 Opmerking:
What kind of cord is required to connect them?
door
Voeg je antwoord toe
Curt C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 35
Altijd: 85,378
