Ga door naar hoofdinhoud
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 Vragen Bekijk alle
Original 3ds, blue light turning on and then turning off
Hi there i have a 3ds CTR-003 model and yesterday i tried to turn it on but the blue led indicator flashes for 1 or 2 seconds and the console does not turn on it does not make a popping sound ether i have no clue what it might be .
Update (05/12/2017)
i installed A9LH susceffuly and know its turning on but it keeps spasing out always going down i dont know what it might be any ideas
Is dit een goede vraag?
Score 2
1 Opmerking
Did you by chance try to install A9LH or Luma before this happened?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
This is a brick, unless you have a NAND backup then you may not be able to easily recover it.
If you have a NAND backup then follow this guide and set up your SD Card with the NAND Backup and the GodMode9 app, boot into GodMode9 then install the NAND.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
door
Voeg je antwoord toe
hugoifer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 3,226
