Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4643 Vragen Bekijk alle
Some Keyboard Buttons Not Working iPhone 6
OK so when I replaced my iphone screen with a new the screen is working but there are 2 buttons that are not it the x and d buttons don't want to work for some reason and when I try to slide to turn off the phone it won't slide down smoothly or not at all
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
3 Antwoorden
Gekozen oplossing
Sorry to say it's most likely a bad screen.
If you replaced it yourself double check the screen connectors if plugged in or dust between them.
If it was repaired by someone else take it back to them and talk to them about the issue. Usually under 30 days they should replace it under warranty free of charge.
Was dit antwoord nuttig?
Score 3
Commentaar:
The Thing Is i went throgh two screen and it was the same for both and i used some compresed air to clean the inside still the same thing
door
I would hope it is just a bad batch. It is more likely that you may be have issues with your motherboard connection. Does the screen touch on the x and d button and on a different screen at all?
door
on one screen it did but the recent two it didnt for some reason
door
If you see the touch screen / digitizer connector on the logic board looks fine under microscope and no shorting or dust / burn marks on there then I think it's safe to say it's a bad batch of screens.
If it was a touch IC issue for this instance the screen would either work or not work at all (on and off but not some areas not touching) intermittently with sometimes grey bar on top.
door
I don't even know anymore I literally just got a other screen the same thing is happening
door
I phone 6 keypad some time working some time not sreen replased but same
Hi Everyone, I have the same issue. Basially the touh screen doesn't work when I press where the letters R,T,D,F,G,C, and V are... I tried doing a hard reset, and even reset it as a "new phone" but still doesn't work. Any ideas on how this can be fixed?
Note: I don't have any cracks on screen..
Voeg je antwoord toe
Sergio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 14
Afgelopen 7 Dagen: 121
Afgelopen 30 Dagen: 495
Altijd: 13,547
