Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
TouchID intermittent after screen replacement.
I recently replaced my cracked screen, moving the original home button from my old screen.
TouchID ever since works intermittently. One minute it will be working and the next it won't. I've noticed that if I lay the phone flat on a table, face down, and knock on the back a few times, most of the time TouchID starts working again until the phone is jostled around.
The button is properly seated, and the connector appears properly seated, the shield behind the home button is properly tightened but not too tight, and the flex cable appears undamaged. Powering on and off seems to have no effect.
Can anyone recommend what to look at next?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
After checking connectors it was still doing it. Decided to double check everything, did a backup then a Dfu restore.
Restored from backup and it seems to be working touch wood.
Was dit antwoord nuttig?
On the board, check the connectors (lcd/digitizer/home flex/front camera) and try to clean away any debris that might be obstructing a flush connection. If that is not the case, the long home button flex cable that run behind the metal plate might be defective.
1 Opmerking:
Thanks. I'd already checked the home button repeatedly but didn't think to check th screen connectors. One of them seemed slightly loose so I'll see how that's goes.
door
Check the Home button connector and make sure all pins are in straight lines. remove any extra stuff on connector both on the home button and on motherboard. aslo check the home button flex. replacing it might solved the issue.
Voeg je antwoord toe
alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 399
