Ga door naar hoofdinhoud
The Singer EZ-Stitch Chainstitch Sewing Machine is meant to help beginners create their own fun and creative projects. It can be used to assemble crafts, clothing, pillows, accessories, and more.
How do I make it stitch? the peal works, the needle moves, no stitches
and yes, i threaded the needle, and it is all looking fine, but when i try to sew, nothing stays. the needle goes in and out and the thread trails uselessly behind.
is there anything to do about this?
peace
K
Update (03/22/2017)
this machine does not have a bobbin. it also came with no instruction manual.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
stroicielka, The video link below are the instructions to ensure you are setting it up correctly and shows how to thread properly. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=hZMjVYQs...
Was dit antwoord nuttig?
Score 2
Have you threaded the bobbin or thread it correctly? Check your manual for proper procedure on this
Score 1
a very important tip for bobbins is the direction that you must follow the instructions for the directions in which the bobbin unwinds!
Voeg je antwoord toe
stroicielka zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 756
