Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
426 Vragen Bekijk alle
disc not reading but spinning
Disc not reading when inserted but can be heard spinning
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There are several things that often cause this problem:
1) Dirty discs...I'm sure you've already cleaned your discs but it might be a good idea to clean them again just to be sure.
2) Sometimes people (or kids) put foreign objects into the disc drive and that can definitely cause it.
3) It's possible that the laser inside the disc drive is faulty and not reading the disc correctly.
4) There could be some other random problem with the drive causing it not to read.
Hope this helps.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
bazevo79 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 2,110
