Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1338 Vragen Bekijk alle
Can I install Server SSD 2.5inch SAS Drive into MacBook Pro 13” 2012
I would like to enquire i just boughtSanDisk 1.6TB LB1606R Lightning Read-Intensive 6Gb/s SAS 2.5" SSD, MLC, Up to 410MBs Throughput, 3 Year Warranty
i wanna know the PROs & CONs...
https://www.corporatearmor.com/product_i....
My question is ..is it possible for me to install it into my MBP 13” 2012 2.9ghz i7?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
Here's some good reading on the different drive interfaces: Understanding SCSI, ATA, SAS and SATA
door
This drive is intended for large server systems not desktop or laptop systems. I would recommend you return it and get your money back as just isn't anyway to use it here.
door
Voeg een opmerking toe
Nintendo Switch-kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Antwoord
Gekozen oplossing
You MacBook Pro uses a SATA interface so no you can't use this SAS drive as it's not compatible.
Instead you could go with either of these two drives:
  • Samasung 850 EVO. They offer both a 2 TB & 4 TB drives. Samsung also offers an ultra large 16 TB SSD as well (well beyond what most people would need)
  • Crucial MX300 The largest they offer is a 2 TB
Neither SanDisk, Kingston or Transcend don't offer anything larger than 960 GB in 2.5" SATA
The SanDisk drive you listed is quite expensive! Why do you think you need such a drive? Maybe we can offer you some other alternatives.
References:
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
khaidir77 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 442
