Ga door naar hoofdinhoud
Repair guides and support for Panasonic's Viera line of televisions.
397 Vragen Bekijk alle
Why does my Panasonic LCD TV turn itself off after 2 seconds
My Panasonic Viera tv keeps switching itself off after a couple of seconds.
The model type is TX-58AX802B. I have tried unplugging it and holding the on button as suggested on other answers but with no success. Can anyone help?
Is dit een goede vraag?
Score 9
16 opmerkingen
@bone1 whenb you say turn off do you mean it shuts off like a no power situation? Besides the reset with the power button, what have you checked?
door
Hi .. i have a panasonic led 50inches Tv. When it is switches on i will have on off image fir about 10seconds..and then the green led will blinking rapidly and turned off with steady red led. anybody have any idea?
Thank you..
door
I have the same problem.. can anyone please answer this.
door
I’m having this problem too
door
door
11 commentaren meer tonen
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
I had the same problem and fixed it. In my case my older TV had dust stuck in the fans. I disconnected the TV, took it down from the wall, placed it face down. Instead of unscrewing the many many screws (some of which were stripped), I took a hair dryer and blew air on the top vents with the fans below. Dust and dirt blew out. I did this for 3 minutes/fan until no more dust came out. The replaced the TV on the wall, reattached cables and voila it works and does not shut itself off
Richard
Was dit antwoord nuttig?
Score 12
13 opmerkingen:
Yes thanks Richard, I just followed your instructions with the hair dryer on cold. It works again and does not turn itself off. All fixed. Fantastic
Gav
door
My 42 inch Panasonic shuts off after being on from an hour or the whole day. When it's off I can only turn it in at the TV, hold the button down either for a few minutes or seconds. Depends, and it'll come back on. Do you have any idea? Appreciate! Peace!
door
Richard you are my hero. Took it to my workshop and blasted out with compressor and so far works just as did before. Was inch away from buying replacement . Cannot thank you enough for advice makes me wonder how many tv chucked away and how much money wasted on rip off ‘repairs’ due to this . Thanks again
door
Richard Wolf thank you so much, I did same thing with the dryer it works, thank you than you thank you.
door
Omg!!! It worked thank you guys
door
8 commentaren meer tonen
@bone1 it does sounds like a power board issue. You do want to remove the back of your TV set and take a look at the board. Check for leaking and/or domed looking caps or anything unusual. Post some images of your boards with your question. Use this guide for that. It will allow us to see what you see.
Before anything else, please double check the warranty status on this set. It is really not that old and may still be covered.
Score 5
7 opmerkingen:
If it is this, can it be fixed or do you need a new board? I have the same issue
door
@noideawithtech either repaired or replaced. It will depend on what exactly has failed. If you let us know the exact make and model of your TV and what the issues are with it, we may have a better answer for you.
door
TX-55AS740B. Hi my Panasonic tv stays on for 1 second and switches off. Can any one help why.
door
I have the same problem the make of the TV is TC-50S2 Panasonic can anyone help out on this issue I am gonna blow the fans and back of the TV to see if dust jammed the fans and that's why it's shutting itself off and wait to see if someone else has a suggestion or a fix ! Thank you for any reply's to this fix.
door
@Jose Arellano have you cleaned the fans yet? what are the results?
door
2 commentaren meer tonen
My panasonic get off my it self
5 opmerkingen:
Same with mine
door
Any help would be much appreciated !
I’ve cleaned the dust but is still doing the same as the previous people did.
Turn on for 2 seconds and after off with stable red light.
Any idea ?
door
@mousaskost what exact model is your Panasonic?
door
Tx-55CX680B
I’ve already change the power supply board and now I am in progress to change the AV board as I see it has something like watermarks on the back of the board
door
Hi I have a 65 OLED and have same issue, turns of after few seconds then blinks slow red
door
TV set turns off while viewing on a recording box in progress
Panasonic Viera. Model number: TX-50CX700B
just switches off randomly with the flashing red LED every 5 seconds. There`s no pattern to it, it can do it 5 times in a few minutes or stay on for a week or more. At the weekend I took off the back panel and cleaned all the dust out of it thinking perhaps it was a build up causing a heat issue, still the same fault.
Voeg je antwoord toe
Andrew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 106
Afgelopen 30 dagen: 580
Altijd: 90,151
