Ga door naar hoofdinhoud
Apple's operating system for its Mac desktop and portable computers.
67 Vragen Bekijk alle
How to recover data from an erased external hard drive on Mac OS?
Hi, I have an external USB hard drive that was initially formatted as Mac OS Extended (Journaled). It was accidentally erased (using Disk utility) and then again re-formatted to HFS. The hard drive has not been used since (other than to try and recover the data using various tools), so no new data was been written to it.
Can anybody suggest any methods or software that could be used to recover the data from my external HD?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is what I use: ProSoft - Data Rescue you'll want at least the 16 GB version so you don't need to create your own recovery drive. If you have a big drive you'll want the larger recovery drive as the files are copied to the rescue drive.
I'm not sure if any recovery tools can recover your data. Its possible the way you reformat the drive might have scrubbed the drive to a point you can't recover your files. I wish you luck!
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Go for Stellar Phoenix Mac Data Recovery software to recover formatted (re-formatted) external hard drive data. Being an external disk you will not require a boot CD to recover data. It will be a just a go. However, was your external hard drive a backup media (such as Time Machine) or do you have password enabled on it? The mentioned software suppoerts Time Machine hard drives and encrypted media as well.
Remember to use another media to save the recovered data perhaps you can save all the data on Macintosh HD itself from the external drive and later move it back to external HDD.
door
Voeg je antwoord toe
Carrie Longme zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 6,725
