Ga door naar hoofdinhoud
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Vragen Bekijk alle
Coconut Battery says Battery Failure Yes (83) with new battery
I am getting a battery failure #83 with a new battery in coconut, otherwise it's working.
Is the new battery defect and should be changed?
Update (03/16/2017)
here it is
Is dit een goede vraag?
Score 5
19 opmerkingen:
I have written an email to Chris Sinai (from Coconut-flavor) and requested help from the horses mouth>
door
Thanks, that's kind!
door
Chris never responded, sorry. But I also got in a new battery this week with this same failure. The battery only had 53% of the maximum capacity, weighed about half of what a normal one did. I got my money back and the supplier didn't even want it back.
door
ok, no problem, just did it myself as i was thinking of returning the battery. yours sounds like a rip off. mine was not the cheapest on the market but also not the most expensive, and i am quite satisfied with it. would have returned it back also if it would have been like yours.
door
Thats definitely an aftermarket battery. That means ur battery has 83% of life left with only one load cycle. Usually u should have over 200 cycles on a OEM battery. I would try to get my money back or trade it for a new one
door
14 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
It is just fine. It happens when u get an aftermarket battery.
Was dit antwoord nuttig?
8 opmerkingen:
@sherlock_holmes ‘It is a capital mistake to theorize before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts.’ -A Scandal in Bohemia
Can you back that statement up?
door
@sherlock_holmes sorry, your answers are partially complete nonsense. i want to point out one of your first answers: "Thats definitely an aftermarket battery. That means ur battery has 83% of life left with only one load cycle. Usually u should have over 200 cycles on a OEM battery. I would try to get my money back or trade it for a new one
16.03.2017 von Lord Vader's Finest Rocketeers " error code 83 has nothing to do with life left. you were mixing up % with codes and so on. please think twice and write nothing before nonsense. nethertheless thanks for your well-mentioned help.
door
What is the designed capacity have? And why was the answers and comments sent to just comments?
door
Is the bottom picture of the old battery?
door
Because there is an error code for that as well. Sorry btw. That was my bad. I don't know what I was thinking
door
3 commentaren meer tonen
Voeg je antwoord toe
heribert weber zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 11
Altijd: 4,966
