Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1488 Vragen Bekijk alle
Flickering screen and battery quickly drain
Dear ifixit,
this is what happened. I had one of those mobile battery that you just plug to the power slot of Iphone and it will charge your Iphone right away.
However silly me ;(, I charge this battery for the first time like this:
wall charger connected to (Iphone with this mobile battery plugged).
It initially won't charge at all.
Now some strange issues I had are:
1. My phone will charge just fine and the brightness is just fine IF it is connected and charged to my laptop. Otherwise, the screen will completely dim and it's almost unviewable
2. It will just charge for a while with the wall charger BUT black out after I left it for a while
any solution to this problem?
Is my screen fried ?
is my battery fried?
or what?
thanks before
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
it is not your scree. Have you checked your setting dealing with the backlighting. and after you have checked that, make sure the battery is still good. If it is not, purchase a new battery and everything should be better for you.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Heru zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,550
