Ga door naar hoofdinhoud
The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
66 Vragen Bekijk alle
Why can't I print a card sized 4.9 x 9.8" using custom settings
why can't i print a card sized 4.9 x 9.8" using custom settings, i get a response that the printer does not support that size despite printing it on several occasions previously?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
How big an area are you trying to print? You may need to use the next smaller paper size, that should work. The only down side here is the larger margins.
Was dit antwoord nuttig?
You should be able to print that size, what may be going on is that the paper width needs to be 4.5" and length set to 9.5", you may have to change orientation from Portrait to Landscape.
Voeg je antwoord toe
Denise zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 35
