Why are my Rear Brake lights not working
We checked the fuses and they seem fine. Two years ago we had a huge problem with the wiring harness, it would loosen it's connection from our dirt road and the truck would just shut off.
Is dit een goede vraag?
2 opmerkingen
I'M HAVING a similar but weirder problem - in my ford econoline 350 1989 - the rear break right light doesnt work but ONLY when the headlights are on - the turn signals work perfect - its not the bulb - break lights work when headlights are not on - but as soon as they are on there is no power to the back right break light only?? please help
door Mark daniel Abadi
Mark, I had 3 different 89 econolines, all with that issue. its a weak ground. what you need to do is find which wire is the ground wire coming from the light, and splice an additional wire onto it, and attach the other end of the new wire to the body or frame.
door Bob
