Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Black screen with grey Stripes!
My phone all of a sudden started to show this screen in the pic! I tried to reset the device but it didn't help!
Does anybody have an idea about what is going on ??
Update: Screen was replaced but I still have the same issue!!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
@dasan is right. Something caused this to happen. Phones don't break all by themselves. It technically can happen, but this would not be the result. If the display connectors aren't placed properly I could see this happening, also this looks like damage to the display. I would recommend reseating the connections using this guide
iPhone 6 Vervanging van het scherm
If that doesn't take, I would recommend using this display, you could save some loot, buying it somewheres else, but you'll likely yield bad results. Part doesn't work, then how to exchange? You can't
iPhone 6 Screen
@dasan. This is not personal. I'm trying to reward you. Learn English better, yes you're right we should be learning your language better. But, I'm sorry, that will never happen. Why I can't say. Thank you for helping. You sound like a good repair technician. Keep helping here! Please! We would love to have you helping in the community! Together we are strong! I know you have information we don't. This site is for sharing information and fixing answers, so we can help! It is a thankless job, which I'm working on that part
Man, I'm just tryin to have a scotch and check my order status...
iPhone 6 Screen Afbeelding
Product
iPhone 6 Screen
$44.99
Was dit antwoord nuttig?
Score 2
1 Opmerking:
So your telling my english is bad ok no issues i can correct it
door
Het nuttigste antwoord
Can you tell me the device had fall? try to refixed the display once, if not it is fallen then the display is got damaged inside and needed to replace.
Score 3
3 opmerkingen:
No it didn't fall! I was just using the device and suddenly the screen was frozen ! I tried to reset with power and home button but it didn't work!
door
Ok pls check with new display fixing and try this faulty display in other iphone 6 device and let me know
door
I did !! still have the same problem!
door
UP UP UP UP UP Up UP UP UP UP
Voeg je antwoord toe
Felipe Wilson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 3,282
