Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
black screen with stripes
The phone of my girlfriend fell on the ground. The screen is not broken but we only see a black screen with some stripes in it. The stripes sometimes change position if I restart the phone.
I would try to repair the phone but I don't know which part I need to repair.
I hope somebody can help me
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
ok so basically your screen is multilayered, just because the glass on the surface is good doesn't mean the LCD underneath is not damaged. basically from the look of it the touch screen is still intact but your LCD is damaged so youll need to have that replaced.
if you google "how a touch screen works" and goto images youll see what im referring to
sucks, but atleast its just the screen!
Update (03/07/2017)
the shield plate is just the "heatsink" so its not the actual LCD so youll need the LCD screen and digitizer and you should be set.
Was dit antwoord nuttig?
Score 1
@logixal Thank you for the answer
Do I need to replace the whole screen: iPhone 6 LCD and Digitizer
or only the LCD shield plate: iPhone 6 LCD Shield Plate with Sticker and Home Cable
iPhone 6 LCD and Digitizer Afbeelding
Product
$69.99
iPhone 6 LCD Shield Plate with Sticker and Home Cable Afbeelding
Product
3 opmerkingen:
updated my answer
door
really quick, can you do anything with the phone? restart it or anything?
door
try doing a hard reset, hold the power button and press and hold the home button until it restarts.
door
Voeg je antwoord toe
KevinZutterman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 113
