iPad will not recharge.
The Battery logo light shows up , but will not charge. Battery is so low it will not reboot by pushing Home and Power buttons. I have tried various other chargers and cables that are working on other iPads.
It seemed to be charged and working fine but then went black and will not charge and/or start.
Is dit een goede vraag?
3 opmerkingen
first thing id try is cleaing out the the 30pin connector dock, and try charging again, if that doesn't work, replacing the dock would be the next option, then battery...
door rayeasom
Thanks for your answer. Comment below.
door bbmack
The iPad Air series uses the 5-pin lightning connector not the 30-pin connector for the charging port.
I wonder if it's just a loose battery connection.
door Ben
