Ga door naar hoofdinhoud
The HP Deskjet Ink Advantage 1515 is an all-in-one desktop inkjet printer/scanner by HP. Model number B2L57A#AKY.
6 Vragen Bekijk alle
Why the printer won't print
I tried printing but the paper just came out blank. Why?
Is dit een goede vraag?
Score 2
4 opmerkingen
I just replace the ink but can't print because the printer doesn't seem to grab the paper, the paper just went in half way and nothing was print on it.
door
Hi @ adnan abdul ajis,
If you have the HP 1515 can you copy or scan a document OK using the printer's control panel?
If it works OK this way, can you try a test print from the computer that the printer is connected to? (usually found in the Printer properties area in the computer)
door
hey my printer hp 1515 just wont print . i press print from my laptop and nothing happens
door
hey my printer error, it can scan but its cant prin, and i can open the properties..
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
No ink maybe? Lol does the rail for the ink cartridges move? Or does it simply spit the paper out
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Leolando Nable zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 3,228
