Type-c port burnt, can't backup anystuff
how do google identify if i hv open the phone before? cus my charging port burnt and i need to take the battery out and charge it to backup my stuff, it is kinda important
Is dit een goede vraag?
I don't think there is really a way google knows. And when your charging battery be careful or use a charging circuit as overcharging phone batteries can result in a firey mess
Was dit antwoord nuttig?
In case I successfully pull out the battery, and I wanna charge it, wat can i use to charge it directly?
You would need either a variable power supply (Expensive) or a LiPo battery charger. I WOULD NOT use any other method as LiPo batteries can be dangerous and if they are improperly charged they can result in an explosion. What even happened to your USB-C port that made it not work? Maybe that can be fixed? The best option is to take it to a repair shop near you. They will be able to charge the battery and maybe even fix the phone while there at it.
no i dun wanna change the port as i change a big part of the phone, the type-c port got burnt and i cant do any backup before sending to google as i have 0% battery left. so i wanna charge the battery and give it back to google
Then you would have to find a safe way to charge the battery
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 387
