Ga door naar hoofdinhoud
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
797 Vragen Bekijk alle
orange screen no response
when i turn on my Kindle fire the kindle logo appears for a few seconds then the whole screen turns orange and nothing works, this is the second kindle i have had with the same problem, seems to be software but usb connection not working either.
Is dit een goede vraag?
Score 11
4 opmerkingen
Any luck? I have the same problem.
door
My screen turned orange, but that’s not all. The real problem is that it shows a partially filled page to Register my Fire. Password missing, so I write it, but nothing happens. Is non responsive.
If I try “forgot password” it sends an e-mail with an OTP but when I enter it, again, nothing happens.
I tried to reset the Fire from the Amazon page, but it doesn't work… apparently it can’t connect to the Internet.
Can any one help?
door
Mine starts up goes blue and then goes Kindle fire again then goes to bootloop
door
My Amazon tablet has went orange on my screen. Everything is working and letting me do things but it is so annoying and I need help!
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
swipe down from top of screen
select settings
select display
select "Blue Shade"
look down at "Automatic Activation
to the right side of the screen there is an oval with a dot to the left
Swipe this dot to the right. It will restore your screen to the normal color
Was dit antwoord nuttig?
Score 10
7 opmerkingen:
Thanks so much. I'm glad I came across you before I had a chance to go crazy. It was nice and super easy.
door
I have to thank you too !!!!!
door
Same here - usually when I try peoples online suggestions for various things, the problem still exists. Yours was simple and worked.
door
Thank you!!!back to normal color
door
Thank you so much. I knew how to brighten the screen but, the screen stayed orange until I read your instructions. It saved us a trip to the computer store and money!!
door
2 commentaren meer tonen
Voeg je antwoord toe
Diana Osborne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 21,932
