Ga door naar hoofdinhoud
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4916 Vragen Bekijk alle
Replacing motherboard will the iMe change or stay the same
New motherboard will I get a new iMe or will it be the same one
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
7 Antwoorden
Gekozen oplossing
The main board is the phone, changing it is almost equivalent to changing the entire phone, of course it will change.
Was dit antwoord nuttig?
Score 4
Commentaar:
is it good idea to change motherboard (if yes why? if no why?) or we should go to new phone? please explain in detailed
door
Het nuttigste antwoord
Yes. Every motherboard has its own unique IMEI number. So if you take out your current board and swap in a new one, the IMEI number will be different.
Score 5
Commentaar:
chane my motherbord miy1
door
door
10000% incorrect. The IMEI number on every logic board is unique.
Score 3
Commentaar:
I given my mobile at the service center & they replaced its motherboard but problems in the mobile remained same, also I didn't get any new emi no.
I think they didn't replace its motherboard, did they?
door
No pliz they didn't change anything
door
Yeah they probably didn't. Yeah I replied pretty late..
door
My phone samsung s8+ has an issue with the iris scanning.so they changed the mother board. But to my surprise it has still the same Imei number ...
door
Yeah because they can change the IMEI and S/N on the board, they probably replaced the IRIS scanner instead but who knows.
door
3 commentaren meer tonen
M swaped my iphone 6 last year. When I receive new phone its emei number was changed.
If I replace my logic board would my imei stay the same ?
Commentaar:
Each & every New/Used Logic(Motherboard) comes with a Unique IMEI Number Embedded with it. So, Obviously you'll get a New IMEI Number of the Swaped Board. But, those can also be Changed
door
I given my mobile at the repair shop and he swaped its motherboard with someone else old phones motherboard,is this safe or not???
Which chip or area on motherboard has stored the IMEI number?
Voeg je antwoord toe
Mark Anderson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 311
Altijd: 22,975
