Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
426 Vragen Bekijk alle
xbox one storage/hard drive enquiry
Hi! New to xbox soon. Do you need a laptop/pc when changing storage/ hard drive on xbox one like you do with ps4?
Is dit een goede vraag?
4 opmerkingen
Justin G, thanks for taking the time to answer my query. Also, for all the information you gave. Much appreciated!
door
It's what I love to do! Is it the Xbox one S or just the one? Feel free to contact me when you get Xbox live and maybe we can join up on there!
door
Are you talking about internal or external? If it's an internal your talking about the below answer doesn't work.
door
Justin G. Xbox one s - FIFA 17 1T
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
No, the xbox will format the hard drive itself.
Scroll left from Home to open the guide.
Select Settings.
Select All settings.
Select System.
Select Storage.
Select Manage storage. If you see your storage device listed, your console has detected it.
If your Xbox doesn't recognize this right away..
Select Settings.
Select System.
Look under Console info & updates. If it says Update available, there’s an update you need to install.
After you’re done installing the update, go back to Settings and select System, and then Storage. See if your device appears in the list.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
john paul zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 104
