Ga door naar hoofdinhoud
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Vragen Bekijk alle
It wont turn on
I have a macbook pro 2015 I got it used from liquidation site i bought it like that since and a student I cant affort to buy a newer one and my hope is fix it , they took the ssd out but the problem is that the macbook pro does not turn on I albready open the laptop and it looks ok to me .
you guys think by not having the SSD it is why is dead
regards
David
Is dit een goede vraag?
1 Opmerking:
If you disconnect the battery, unplug the charger, then plug it back in, does the fan spin at all?
door
Voeg een opmerking toe
1 Antwoord
Are you getting indicator lights? Does it charge? Any signs of life when you press the power button?
If you get nothing at all, it's a good idea to discharge the power circuit. Remove the battery and AC cord. Hold down the power button for 10-30 seconds. Without letting go, reattach the AC cord and continue holding power for another 10-30 seconds. Release the button and try turning it on normally.
(On Windows machines, this is also a good way to clear the CMOS on some machines.)
Was dit antwoord nuttig?
1 Opmerking:
It has a amber light when I connect and the charger and by pressing Shift, Control, and Option keys on the left side and the power button, all at the same time I can see it becomes green and flashes 3 times and after that it goes back to amber but it is completetly dead :(
door
Voeg je antwoord toe
davidmiranda33 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 801
