Ga door naar hoofdinhoud
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
41 Vragen Bekijk alle
Can I put a single cab transmission into a extra cab truck?
both trucks are 94 rangers both have same motor is the transmission going to match up with the driveline or will i need the driveline off single cab?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
94 and 95 had Two transmissions for this truck A4LD which was with an overdrive and a 4R44E which was used till 2000 They both will work for you but you do need to measure the tail stock . As long as the tail stock are the same length then you wont have a problem.
Was dit antwoord nuttig?
Score 3
@carenlove yes you can.
Score 2
Voeg je antwoord toe
KAREN LOVE OLEARY zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 174
