Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Used Red ring repair kit a month ago, problem came back
What can I do, if any, after using the Red Ring of Death repair kit and the problem came back after only one month?
Any suggestion!?
Thanks
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Commentaar:
Thank you, Chris Green for your recommendation, however it did not fix the problem.
Any other suggestions would be greatly appreciated.
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
I would recommend opening it again, and loosening the heatsink screws, then re-tightening them evenly, that should do it.
Was dit antwoord nuttig?
Score 3
Commentaar:
Hello Chris, You are invited to join the master tech team if interested.
door
Master tech team?
door
you can do it your self , heat gun and repair x and remember to use the grease under the cpu , the heat gun is like when the xbox is turned on , they heat up thats why the heat gun works , reflow the solder joints , ytube will show you the area to work on , it works
Score 1
Old question, but I need to make some things clear for someone who doesn’t know better. These Xboxes cannot be repaired, nor is reflow repair. It is a temporary fix that kills the GPU after multiple patches to the problem. The Xbox is not immune to this. Reflow is not repair and it never has been.
It can work to save data (and I’ve done it for that purpose before), but the device is condemned once I have what I need.
The problem is the balls under the actual chip die fail, rather then the ones on the board - you are reflowing the underfilled balls and not the motherboard itself. Do yourself a favor and remove the hard drive from the fat 360 enclosure so you can convert it to a S/E drive and get a replacement that’s actually going to last.
Score 1
Zack,
The rrod repair kit is not doing it for you because your motherboard has probably succumbed to the flexing. You should get a reflow done by a professional with a real reflow station + preheater.
Avoid the people who use heatgun + hot plate/griddle.
The xbox I have from a total over heat and could not turn on and play. The xbox is still working with no problems .its a 50 50 shot that the balling of the chip or the heatsink has a problem with the solder joints you have to start somewhere the culprit is overheating and that's why I got a new x plate and bolts and paste
Voeg je antwoord toe
Zack Paniel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,026
