Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
616 Vragen Bekijk alle
Home button not working after USB Charge Port Replacement
My friend has 2 Galaxy S5 phones. One is a G900A and the other a G900T. He replaced the USB Charge port on both. On a GS5, the charge port is on a daughter board which also houses the home button and soft buttons. For some reason the soft buttons work but on both the home button no longer works. Even the original ones he had don't work anymore. I took a look at it, and I couldn't see anything wrong. I even double checked the iFixit guides. We also had the seller of the parts resend replacements and bought another from a different source. All have the same problem. Does anyone have any idea?
Is dit een goede vraag?
Commentaar:
@avanteguarde
I've noticed you've been inactive the last few days. Something wrong?
I will find you. I will fix you.
Ifixit play on Leon Neeson
door
Samsung Galaxy S5 Teardown
See steps 6 and 12 for insight on the home button and its cable. That's the best I've got to offer.
door
@pccheese, Internet problem. Windows 10 updates will swallow your bandwidth whole!
door
Are you on DSL? We've got 6 windows 10 PCs and we never have a bandwidth problem. You've been out for days!
door
Yeah, DSL. Try running 10 Windows devices on that! Especially with the creators update coming.
door
1 commentaar meer tonen
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
1 Antwoord
The home button on the galaxy s5 connects directly to the MB if I remember correctly. Double check the integrity of the board side (female) connector; if the home button got pulled out without being properly unplugged it could be causing the issue.
Was dit antwoord nuttig?
Commentaar:
@xela, no, the home button is part of the charge port daughterboard along with the 2 soft buttons. The soft buttons work, but the home button does not. The chargeport has been change 2-3 times from different sources, but the home button still does not work.
door
Voeg je antwoord toe
S W zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 662
