Ga door naar hoofdinhoud
Is it possible to install the A1212 logic board into an a1151?
I have an a1151 17" MBP that has a toasted logic board. I want to replace it with a logic board from the a1212 machine (faster core2duo processor). The connections look to be in the same place and of the same type. Has anyone actually done this? Any help you all could provide would be extremely helpful and appreciated!
Thanks!
Cransy
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Unfortunately, the connectors are not the same. Apple switched the connectors on fans, thermal sensors, and inverter to JST type connectors. You'd need to switch out all these components as well.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,069
