Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1623 Vragen Bekijk alle
Backlight has gone! Screen not working.
Ok so I've decided to salvage my MacBook Pro it has been broken for about a year. When I hook it up to a screen it is fine and when I shine a light through it you can see it.
I have tried resets etc.
Any help would be great!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It may be a backlight fuse failure on the logic board. If that's the case it should be replaced but requires soldering skills and a very good magnifier or microscope. Yet it should be considered that if the fuse has gone, something has caused the failure and needs investigation..lcd connector, something wrong with the screen itself ?
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Jemma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 45
