Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
The screens on my 3DS are messing up, how do I fix it?
I accidentally dropped my 3DS XL and the bottom screen is black and mirrored only showing images in inverted colors, the top screen has a pink color and if I open my 3DS XL all of the way, it shuts off immediately. Does anyone know a solution for this?
Is dit een goede vraag?
1 Opmerking
HELP! I tried fixing the A button but now my top screen is tinted pink and flipped!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like both screens are faulty, you would need to follow the guide in here on how to replace them. The reason it turns off when you fully open it is that the top ribbon cable for the screen is getting more pressure on it when you open the hinge all the way so it is probably disconnecting.
Unless you have experience with taking these apart I wouldn't recommend trying to do the top screen yourself though as it's very easy to damage the top screen ribbon cable.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
My nintendo screen is pink at the top.. But the bottom is fine..
door
Same here, my top screen is blue but my bottom screen is perfectly fine. If I press on the top half of the 3ds, it then changes from pink to it's normal color until the pressure is released.
door
Voeg je antwoord toe
Gabriel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 2,979
