Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1863 Vragen Bekijk alle
Can I use a home button from another iPhone 6s to retain touch id?
I have a broken home button but I would like to keep touch id so I don't want a replacement home button. If I get a original home button off another iphone 6s will i be able to keep touch id?
Thank you for you're help!
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
3 Antwoorden
Gekozen oplossing
you can your but touch id function wont work why because your original touch id paired with cpu...
if you put another touch id finger print not work
so you not able to use touch id function
you can use for menu button function
Was dit antwoord nuttig?
Score 2
Commentaar:
That's what I was wondering. Because I have two original home buttons from apple but one broke so I thought I could change them over. I guess they're locked to the logic tho .
Thanks for everyone's help
door
Doesn't matter if it is original or not, if you replace the home button Touch ID will never work again UNLESS you take it to Apple and say it doesn't work. They will use their magic pairing thingermabobber and it will work again. So yes, it CAN work again, but not without a trip to Apple! :)
Here's the part:
iPhone 6s and 6s Plus Home Button Assembly
Score 1
Hi
Plz Go Thorugh Below Link
https://www.youtube.com/watch?v=Zv1LO9vG...
Hope it Works
Thanks
Varun
Voeg je antwoord toe
Shawn Daw zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 93
