Ga door naar hoofdinhoud
Guides and support for devices that play video from DVDs.
272 Vragen Bekijk alle
DVD recorder/player suddenly not reading discs.
Re: My Panasonic DMR EA14 DVD recorder and player: DVD discs I've recorded & finalized myself on the Panasonic, & watched many times, suddenly not able to read/play. Error message: "Unsupportable Disc." Discs DO playback on my MacBook, & the Panasonic IS playing store-bought, pre-recorded DVD's. Also, suddenly having some difficulty recording on discs with previous recordings on them & plenty of recording time left. Hope someone can help. Thanks very much. - Julie
Is dit een goede vraag?
Score 3
2 opmerkingen:
my Panasonic recorder, DMR-EZ45V , suddenly can not read DVD discs , any suggestions how could I repair it myself ?.
Many thanks in advance
Mati Basis
mnbs53@tiscali.co.uk
0208 444 7833
door
I have the same problem with my Philips DVDR 3355 :(
any suggestions? I cleaned the laser head but still the same
door
Voeg een opmerking toe
3 Antwoorden
Try to clean it with dvd cleaner disc
Was dit antwoord nuttig?
1 Opmerking:
Thank you very much. I will try that.
door
My Deawoo is the same - one month after warranty ran out. Will not recognise even some pre-recorded discs , and cleaning with "Laser Head Cleaning Disc" does not work. I took it apart and wiped the laser head gently with optical cleaning fluid - still the same. I think must be some electronic fault, which is too expensive at repair shop - so just buy another! (Second hand ones are cheap)
Could be a simple mechanical/dirty grease pb, see my post here :
will only paly home burned DVDs
(or maybe http , no "s")
sorry, I have to go for now ;-)
Voeg je antwoord toe
llebrew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 12,803
