Ga door naar hoofdinhoud
Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
When my phone won't charge.
Hello I need your answer please.
My phone won't charge. Every time I put the charger unto it, at first it will charge then after maybe 1 minute it wont charge again. I used every charger at home but still it won't charge. I removed the battery and restart but still nothing happened. Is it because of the battery or the phone itself?
Please respect my question and I am looking forward for your suggestions thank you :)
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
By not charging after 1 minute do you mean that it doesn't charge as in the battery percentage doesn't go up? Or do you mean that it's not detecting that a charger is even in the USB port? Also, if you could, try plugging it in and wiggling the USB connector around inside the port a little bit, if it connects and disconnects every time you move it around then your port is probably damaged from being used so many time, it's just from usage. Take a look inside if you can and see if it's messed up. If that's the case then you'll need to take it to a repair place to have it fixed unless you know how to solder because on this model the USB port is soldered onto the main board. If it isn't damaged and wiggling it around doesn't do anything then I would try a factory reset and if that doesn't work I would try flashing it, if that fails then I would send it in for a repair because a chip might need to be re-soldered.
Was dit antwoord nuttig?
i bought a new battery put it in my phone on charge and it doesnt show that its charging. why?
i tried everything best bet is to clean out the port ,or take something small and lift up the tab in side the charger port gently to make sure it is touching the metal all the way
Voeg je antwoord toe
Jezreel Obedencio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,623
