Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
Bluetooth can't be turn on. No toggle - loading icon instead.
Hey!
I'm recently experiencing an issue with my customers iPhone 6 Plus.
The problem is if you go to Settings -> Bluetooth you can only see the Bluetooth heading and instead of the enable/disable toggle switch there's some kind of 'loading' icon. It just keeps spinning forever.
Already restored it, installed latest firmware through iTunes (both normally and through DFU mode), tried reseting network settings alone - none of these would work.
Any clues?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Wifi antennae
iPhone 6 Plus 5GHz Wi-Fi Antenna Replacement
iPhone 6 Plus 5GHz Wi-Fi Antenna Afbeelding
Product
$7.99
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Thanks for response imedic! Also thought about it but wifi itself is working fine. Is it possible that only one of these modules is damaged on the antenna part?
door
That is kinda strange, did you recently update iOS? Also try resetting your network settings
door
That's another example of trying to replace the tires when your car won't start.
door
Bluetooth chip problem, replacing the antenna will not help in any way.
Get someone to diagnose and repair the board for you.
Score 1
I have the exact same problem. Did you find any solution?
Voeg je antwoord toe
ddomanski94 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 492
