Ga door naar hoofdinhoud
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1015 Vragen Bekijk alle
Replace screen assembly MacBook Pro retina 13" Early 2015
Hi All,
Sorry if the questions has been asked already.
I need to replace the full screen assemble of my mcbook pro retina 13" early 2015 A1502 EMC 2835.
Have been told that the EMC doesn't matter and that I can replace it with any A1502 as they are the same 2013 onwards.
Is that true?
Many thanks
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I don't know if this will help or not, but
MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement
MacBook Pro 13" Retina (Early 2015) Display Assembly
MacBook Pro 13" Retina (Early 2015) Display Assembly Afbeelding
Product
$449.99
Was dit antwoord nuttig?
Score 5
Commentaar:
You need Apple part# :
661-02360
Earlier 2013 displays will not work.
door
Ifixit says it's for that model. Is it a problem with their listing?
door
The EMC number needs to be the same in order for the top panel to function properly (backlight, webcam, ect.) For a 13" 2015 Macbook Pro the PART number of the top panel you will need is 661-02360. Search for this when purchasing your top panel and you will be fine. Best of luck!
Score 3
Voeg je antwoord toe
FloLDN zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 3,856
