How to replace home button
how do you connect the home button to the ribbon cable?
Is dit een goede vraag?
The ribbon should be attached to a metal "button" which is stickies to the backside of the plastic button. The "button" should be sticky and a specific shape which the back of the plastic button has the same shape where the electronics sticks too. No glue was needed when I applied mine. Hopefully the ribbon isn't detached from the other component or else you'll need a new one. Hope my reply helps you.
Was dit antwoord nuttig?
Use this guide.
look scary. not dare to do it.. any change to change home button in easy way?
This is the only way. There are not short cuts....:-)
That doesn't answer the question. That guide is about removing/replacing a home button with a ribbon cable attached. The question is how to connect the home button to the ribbon cable, presuming that the ribbon cable is no longer attached to the home button.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 7,566
