Ga door naar hoofdinhoud
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
221 Vragen Bekijk alle
Where are the leads of the BL-T9 battery in the Nexus 5?
I can't find the positive and negative leads on the BL-T9 battery to test for voltage after extracting it from the phone. There appears to be only a single connector to this battery.
Where should the test leads go for this battery with a typical multimeter?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
This is a blown up image showing the connector side of the flex cable coming from the battery.
On it you will see the 3 copper coloured connectors in the plug, with what I think is the temperature connector in the middle. By the physical size of the connectors the +ve and the -ve connectors should be the 2 outside ones of the three and using a Voltmeter it shouldn't take much to work out which is which,
click on image to enlarge for better viewing.
Test procedure using DMM -Voltmeter - 20V DC scale
Place Voltmeter red test lead on one outside connector terminal of the battery cable and the Voltmeter black test lead on the other outside connector terminal of the battery cable.
If the Voltmeter has a -ve symbol in front of the voltage reading then the red lead is on the -ve terminal of the battery.
If the Voltmeter shows only the voltage reading then the red lead is on the +ve terminal of the battery.
Ensure that you do not bridge across the terminals with the meter test lead probes when measuring the voltage, as you could s/c the battery.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Thanks. I was able to confirm that the battery still held 3.5V for a 3.8V capacity. Now to figure out why the phone isn't registering it.
door
Voeg je antwoord toe
Rewarp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 2,010
