Ga door naar hoofdinhoud
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
20 Vragen Bekijk alle
Why wont headlights turn off
Headlights stayed on after shutting car off. What do I need to do?
Is dit een goede vraag?
Score -1
1 Opmerking
Are they on while driving, even without turning them on? Do they eventually turn off, not from a dead battery? When you shut the car off, is the headlight switch off also?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Dori,
Check out this thread and see if it helps you figure out your problem.
Additionally, if you google "grand am headlights stay on"
You get a bunch of information on your question and as a shotgun solution you might find an answer to someone's problem that is similar to yours.
Regards,
Frank
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Dori zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 3,690
