Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Vragen Bekijk alle
UIOJKLM keys are not working on my MB Pro 2012 15.4" Unibody
I added a 2nd SSD in optical drive bay (Data Doubler) in my MB Pro 2012 15.4" Unibody. I've done this on a few MB Pros and iMacs and never had any issues. Now UIOJKLM and > keys aren't working. But before that, WiFi was acting up. I couldn't turn WiFi on in ntwk pref, but now it's fine. Just kybd issue.
Is dit een goede vraag?
Score 1
2 opmerkingen
I have the same problem and it just started today (19 Feb 2017), midway through typing something. 7 u i o j k l m . keys won't type. The rest seem fine.
door
Any solution to this problem.I am also going through the same problem
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Go to step #17 of this guide: MacBook Pro 15" Unibody Mid 2012 Upper Case Replacement
Put a piece of tape on the cable, flip up the lock, and pull the cable deeper into the socket, then lock it in place.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
My U I O P keys stopped working all of a sudden. Sometimes they would work briefly but then they would stop for prolonged periods. Did exactly as @mayer said .... AND NOW WORKING AGAIN. THANK YOU. YOU ARE A GENIUS!!!!!
door
Glad I could help ;-)
door
@mayer, Thank you so much for sharing that - lost the number keys 1 through 9 after a repair; your tip to use tape to get the keyboard cable deeper into the socket worked a treat.
door
Voeg je antwoord toe
Xmei Media zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,283
