Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
1676 Vragen Bekijk alle
Is there any way to fix these scratches?
Hello ifixit community! I am new to repairing and today I dropped my iphone and it slid across a concrete floor.
I was wondering if there is anyway to minimize the damage and to cover up some of the scuffs and scratches. I provided an image of the phone. Much appreciated!
http://imgur.com/a/rUIiP
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 2
Commentaar:
So did u manage to remove the scratches or scuffs through polish?
door
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
2 Antwoorden
Gekozen oplossing
@pars , Parsa, The same kits used to polish headlights could be used to get rid of a lot of the scars but probably not the deepest, the kits range from $20-$40 at auto parts and big box stores. You could also consider putting a wrap/skin on it which would clean it right up or perhaps put it in a case. Check the links below for covers/wraps/cases. 1st link is video showing how to wrap phone. Good luck.
https://www.youtube.com/watch?v=wjtSOpwh...
https://dbrand.com/shop/iphone-7-skins
https://www.slickwraps.com/devices/phone...
http://www.bestbuy.com/site/iphone-cases...
Was dit antwoord nuttig?
Score 2
Commentaar:
Thank you so much for the answer! Yeah I already ordered a skin for it, but just wanted to see if there is a way to remove at least some of the scratches if I decided to sell it someday.
door
Also would you mind leaving a link for the polish headlight you mentioned?
door
@pars , Your welcome, see links below polishing kit and 2nd link shows how to use it. Good luck with your device.
https://www.walmart.com/ip/3M-Headlight-...
https://www.youtube.com/watch?v=fvNSjjTH...
door
@pars So did u manage to remove the scratches or scuffs through polish?
door
The headlight solution that L Ptaff had suggested will potentially allow you to buff out the scratched plastic on your phone's narrow antenna lines. However the material on the flat back surface of your device is anodised aluminum. This is a silver metal with a very thin black top layer. Any heavy polishing is likely to strio the black color, revealing the lights bare metal underneath. However, at least if you try the pleasure polish alone, I doubt it would negatively ffect the anodised coat.
Voeg je antwoord toe
Parsa Hasani zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 263
Altijd: 44,285
