Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Headphone Jack/Microphone and ear speaker not working
Having strange problems with an iPhone 6.
Calls can only be heard through speaker whilst nobody can hear me. Microphone not working even with voice memos. Speaker works fine but if plug in headphone continues to play through speaker. Have replaced charge port and still same issues. Any advice? Know phone recently had a new screen replaced by another tech if that could have caused issues.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
I would check for Long-Screw Damage, just in case.
There are three microphones on the iPhone 6. There is one for phone calls/front camera videos, one for noise cancellation and one for the rear camera. Check that they aren't obstructed with dust, wax etc.
Small parts are notorious for being hit or miss. Can you confirm that the replacement port is functioning?
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
Just put another board in out of interest and all works so guessing board trouble
door
Did you look to see if there is LSD?
door
How would I spot this?
door
The connections cover was not on phone
door
Look inside the standoffs (where the screws go) circled in red in this image. (iPhone 6 Logic Board Replacement)
You will need magnification to do this. Ideally a microscope but a jeweler's loupe will do. The bottom should look black. If it looks all scraped up, then it may have LSD.
door
1 commentaar meer tonen
It's the front camera flex
iPhone 6 Front Camera and Sensor Cable
iPhone 6 Vervanging van de naar voren gerichte camera en sensorkabel
iPhone 6 Front Camera and Sensor Cable Afbeelding
Product
$19.99
Score 1
1 Opmerking:
Screen works fine on other phones, all pointing towards board issue
door
had the same problem with a customer I replaced the charge port/mic flex and fixed all the problems
1 Opmerking:
Yeah I did the same thing but turns out it did nothing :(
The probability of this issue is on the logic board's audio IC needs to be replaced.
door
Voeg je antwoord toe
Niall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 9,943
