Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
591 Vragen Bekijk alle
MacBook Pro still won't charge after replacing everything.
Okay so a few weeks ago I was brought a MacBook Pro 15" Unibody Mid 2010 with a faulty logic board that needed to be replaced. I did no testing on the logic board but i was told that Apple themselves diagnosed it as a bad Logic board. So I purchased a logic board off of this site because it would be cheaper for me to do it than have Apple do it.
After replacing the logic board, initially when first trying to get the thing to boot, I noticed that there would be really faint clicks and the indicating light would blink slowly and consistently. After doing an SMC reset I got it to boot, but the cpu and gpu fans would run max speed and the indicator light on the MagSafe charger stays green, never goes to the Amber charging color. Anytime I went to reboot or remove it from the power adapter, I'd have to do SMC reset to get it to boot up. I figured this all had to do with having a bad/old battery since it wouldn't take a charge.
So I ordered a new battery off of here, thinking that would fix the weird power issues. As I was waiting for the new battery to come in the mail, I talked to the owner and he decided he wanted to put in a new Samsung 850 Evo SSD 500gb. I cloned and got the new hard drive installed with no issues besides the current power/no charging issues.
After receiving the new battery, I immediately installed it and just for the sake of trying it, I booted the Macbook up without being plugged into power, only on battery power. Booted just fine, no issues, no fast fans, didn't have to SMC reset, battery read at 61% and correctly saying that it wasn't plugged into the wall. I then plugged it into the wall.... No amber light, just a green light and the battery indicator on the home screen at the top says, Not Charging.
I tear everything apart again, put it back together, clean the magsafe port after removing it completely. Reassemble. Boots no problem but still says Not Charging. Slowly but surely throughout me trying to fix the issues the battery goes all the way down to being dead. Not once could I get it to charge. So after reading a little more online I decided I might as well replace the MagSafe DC-In board as well. Part is cheap and it was the only power related part that I hadn't replaced since the new logic board didn't come with it and I salvaged the one off the old one.
The MagSafe DC-In board came in today and I replaced it and still no amber light. No charge, can't get it to boot without SMC reset. Automatic shutdown on taking off of power. I left plugged in over the weekend, seeing as some people said it does charge but just really slowly. But still no charge. One strange thing is that with the new battery, once I get it booted, there is no battery symbol at the top of the desktop. When I go to power settings and check the box to get it to display, it shows up for half a second and disappears. With the old battery, for the most part the battery symbol will be there but with a black "X" through it.
Another strange thing is with the Original/Old Battery, If I do this exactly I can get it to boot up like it has a charge although only at 1% and still no charging symbol/amber light. But if I turn it off completely, unplug power from wall while still in the MBP, wait a few seconds and then unplug from the MBP, wait a few more seconds, plug back in to magsafe port, then plug it into the wall, it will boot up automatically with quiet fans. Get to the sign in page and the symbol is at the top saying 1% but not charging. It has a the power bolt through the symbol, and I can pull up the power tab on About this Mac and it gives me all the information about the battery. It won't do that with the new battery at all. Follow that to the T and it will only sit there with the low dull click and blinking light until I do a SMC reset to get it to boot.
Almost forgot but I've tried with other chargers/power adapters, tried with different outlets, made sure this power adapter works on other Macs and I've ruled it out from being the culprit.
I've read countless forums on the subject, can't get anything to work. Only thing I can think of is maybe I got a bad part. Any advice would be greatly appreciated, as long as you don't tell me to SMC/PRAM reset like every single forum does.
TLDR: Replaced Logic board, battery, MagSafe DC-in Board, countless SMC resets and still wont charge. Not power adapters part. Maybe got bad replacement part?
Is dit een goede vraag?
Score 3
2 opmerkingen
hi there, did you ever find a solution to this? I have the same symptoms with my 2011 15". I'm wondering if the non-standard battery is causing it even though coconut battery says it's ok
door
Im having exact issue did you find a solution hard drive cable?
door
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
First let's geta better idea of what that battery is doing. Download this free app and run it and let us know your results: http://www.coconut-flavour.com/coconutba...
FYI the most common issue on this machine is a bad hard drive/IR cable. I use the 2012 cable for a replacement: MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable Afbeelding
Product
$19.99
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Coconut doesn't come up with any information since the MBP doesn't even read that there is one plugged in. As for the hard drive cable. It boots to the HD no problem. What would that have to do with the things ability to charge?
door
This is marked as solved and I see no answer??
1 Opmerking:
Right Above your answer david. alternatively you can hit the blue "Answered! View the answer" button at the bottom of the question
door
Ever figure this out? Im having the same problem. But what the above guy said about the HD/IR Cable made me intrigued. Because my cable actually is not fully screwed in where the "grounded" part is (2 loop holes flanking the ribbon midway between HD and logic board. Because i lost those screws but thought it was just for fastening. Could it have some electricity functionality to it thats affecting charging through the DC in?
1 Opmerking:
Hi Arif, did you ever find a solution to your problem? Having an identical problem here, my HD cable screws are tightened however
door
Did you ever figure out what the issue was? I'm having the same problem with the same exact machine. Just replaced the dc-in board without solving anything.
2 opmerkingen:
I recommend open up a new question. iFixit Answers is a Free Repair Q&A
make sure to include details like (a link to this question) some details about your device and past occurrences like water spills recent repairs etc and what you have already tried. Good Luck!
door
Hey did you ever find a solution to this? I was about to replace my DC-in board too but it seems like this won't solve anything. I'm wondering if it's my third party battery even though coconut battery says it's fine
door
Has this issue been solved. im experiencing the same thing after installing a SSD. The other users happen to be installing a Kingston SSD, v300 or something similar?
Having same problem, though I did not replace logic board. I did replace MagSafe port, and it worked fine for a while, then it stopped charging again. Replaced the MagSafe port again, to no avail. New battery, everything boots and runs fine, only power shows no ac connection when plugged in.
So, should I try replacing the logic board…or give up? Concerned about sending good $ after bad.
4 opmerkingen:
Also, no lights at all on charger connector.
door
Hi did you ever figure out im having this issue now......
door
No. It's sitting on desk as I try to figure out whether to throw it in the ocean after removing the hard drive. Terribly frustrating.
door
I left on desk until yesterday( 5/11/2021) and decided to plug in the magsafe. Lo and behold, it lit up and started charging, very very slowly, but charged tp 99%. System would shut down when magsafe unplugged, however. Reset SMC, and battery status changed, but still couldn't run system off battery power. Working on finding out if it's the iFixit battery....several folks have had issues with them. More later. Big improvement, though, because before I couldn't get it to boot and magsafe showed nothing.
door
Voeg je antwoord toe
Corey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 5,005
